Raster Item Explorer - When adding a mosaic dataset image designate an attribute field value to name the ArcGIS Pro layer
438
11-09-2018 10:48 AM
Status: Open
DennisGeasan
Occasional Contributor II
When adding individual  ArcGIS Enterprise Geodatabase mosaic dataset images to an ArcGIS Pro map provide the means to designate a mosaic dataset attribute field value to be the name of the resulting ArcGIS Pro layer.  Currently, the layer name becomes the fully qualified database name using the pattern "sde.schemaName.mosaicDatasetName:OBJECTID".  Lots or work required to then manually modify the layer name when often the actual image name would suffice.  It would be very convenient to be able to use an attribute  value already defined in the mosaic dataset image.
