Provide cursor elevation with 2D map in ArcGIS pro
337
07-13-2017 08:33 AM
Status: Open
jean-michelLAPORTE
New Contributor II
Elevation data are more and more common.
It is easy to load such data in ArcGIS Pro and to associate it like an "Elevation surface" using  the map's properties.
In a Map_3D window, the coordinates of the cursor include the value of the elevation in the corresponding point.
It will be great to have the same with a 2D Map once an elevation surface is defined (a DEM file or an elevation service).
Could be considered also within the coordinates widget of the Portal for ArcGIS.
1 Comment
ZacharyMarvin
The status is now reviewed. Can the developers provide an update on the status of this feature?
