Pro: Change Data Source for XY Event Layer should present geometry options (Like ArcMap)
2078
05-01-2018 12:29 PM
Status: Implemented
ThomasColson
In Arc Map, one can right-click on a XY Event Layer and change the data source to (another) XLSX, XLX, TXT, CSV, DBF, etc...... imagine you got a new spreadsheet showing the locations of the latest Zombie Outbreak.
You can change the coordinate system, the XY fields..
Pro....
5 Comments
KoryKramer
It might be clearer for the title to be something like Set Data Source for XY Event Layer in ArcGIS Pro:
ThomasColson
That might be misleading? The idea is specifically related to the geometry options in Set Data Source when doing it for XY Event Layer...not Set Data Source for XY Event Layer....
KoryKramer
I guess I'm confused then because I don't see how we can get to any options in Set Data Source for an XY Event Layer when that button is disabled for the XY Event Layer in Pro.  So first we need to be able to get into the data source for the layer, then specifically you want to change the geometry options.  Either way, I have this noted as an equivalency issue.  Thanks!
TanuHoque
TanuHoque
It is implemented in ArcGIS Pro 3.4 release. Thank you all for your suggestions and feedback.
