Pro Catalog: Sort by Feature Geometry (e.g. Point, Line, Poly, Table)
1426
12-06-2019 11:37 AM
Status: Implemented
by Anonymous User
Not applicable
In ArcCatalog, you can turn on the ability to sort by Feature Type and sort by the type of item: feature dataset, relationship class, Point, Line, Poly, Table, etc.
Pro Catalog only allows you to sort by Name and the general type of item - feature class, relationship class, table, etc. You cannot sort by the geometry type of the feature classes.
Being able to sort by the detailed geometry type is an indispensable step for finding and managing data in databases with a large number of items. Please add this functionality to Pro Catalog!
ArcCatalog:
Pro:
Feature classes are sorted, but all the geometries are mixed together, with no ability to sort further (at least not that I am aware of).
5 Comments
KoryKramer
This is likely just a specific part of Add Additional Details in Catalog View in ArcGIS PRO
But we should keep this one open.  Ultimately, in ArcCatalog, there are these options:
These need to be included in ArcGIS Pro.
NaicongLi
NaicongLi
Bud
From a separate idea that has been closed: Catalog View — Indicate if object is a database view, annotation, etc. in Type column
In the Catalog View:
Database views are currently categorized as tables in the Type column. And annotation FCs are categorized as feature classes.
Those categorizations seem misleading. Could they be changed to better reflect those object types?
There might be other kinds of objects that aren't categorized specifically enough in mobile geodatabases too. I haven't tested them all. See mobile geodatabase datasets for a list.
Related: Filter Catalog by object type
KoryKramer
This Idea has been implemented in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
The Your Ideas in ArcGIS Pro 3.2 blog and video have been posted to the Esri Community blog. You can take a look at these to see your idea and all others that were implemented in this release of ArcGIS Pro.
