Please fix stream mode digitizing
255
01-26-2021 06:54 PM
Status: Open
IanPryor1
New Contributor III
Stream mode digitizing is still nonfunctional and essentially broken in Pro 2.7. In Arcmap you set a stream tolerance and vertices are created at the specified interval and visibly appear as the mouse is dragged along. In Pro, it is seemingly random how the software decides to create a new vertex while engaged in streaming mode digitizing. Setting the tolerance to 20 feet results in vertices roughly 80-100 feet apart, setting at less than 5 feet results in 4-10 feet spacing, setting it at zero results in imprecise "jagged" results. The results are so horribly inconsistent the tool is practically useless (for my purposes and especially when compared to Arcmap). Please just implement this tool in the same manner as Arcmap or at least give that option.
