Option to show time in local time when data has a time zone defined
654
08-22-2025 08:16 AM
Status: Open
Joshua-Young
Honored Contributor
ArcGIS Pro needs product wide support for displaying time in local time when the data has a time zone defined. I have no problem with time being stored in UTC by default, but my users need to interact with that time in local time. Currently in ArcGIS Online our time is stored in UTC and when my users view or edit the time they are working with local time and the software handles converting the time zones. I know about the Preferred Time Zone setting, but for services from ArcGIS Solutions I cannot turn that on. Plus doing that way seems rather limiting. I would think having the clients handle what time zone to show the data in is more flexible.
In ArcGIS Pro we are only shown UTC time and have to remember to edit in UTC time. ArcGIS Pro needs the ability to see what time zone the data is in and then display the time to the user in local time and allow the user to edit using local time. Then ArcGIS Pro handles the time zone conversions on the backend just like ArcGIS Online does.
I was asked to create a road closure map for an event and we use the road closure solution from Esri. I got the layout setup in ArcGIS Pro but when I added a table frame all the closure times are in UTC. I can find no way to have the table show the times in local time. I went back to the web app that was used to enter the road closures and all the times are "correct" (local time).
4 Comments
EmilyGeo
Thanks for sharing your idea. Managing date and time data can indeed be tricky. We've recently added some new field types that might help, including:
  • Date only: stores only a date value - not subject to change
  • Time only: stores only a time value - no subject to change
  • Timestamp offset- This stores both the date and time, along with the corresponding time zone (offset from UTC).
This article contains more information about new field types and and tips for managing time data.
Joshua-Young
@EmilyGeo thank you for that information. One problem with that is we use ArcGIS Enterprise 11.5 and Timestamp Offset fields are still not supported for hosted feature services. Plus it seems like there are still Esri products that do not fully support the new data fields.
RTPL_AU
@Joshua-Young Agree.  There are other Ideas around Data/Time that intersect this one.
One of mine is specifically around having the same Date/Time displayed all through Pro, AGOL, apps, etc.
@EmilyGeo - was it a decade ago that a 'dumb' date/time field was asked for so we can add date/time data and nothing in the Esri pipeline will try to interpret / UTC-shift / do anything to it?
I still feel that will be easier than this ongoing 'let's make it even more complicated but we don't have the resources to have the same maturity across our stack'  all the time. Pun intended.
https://community.esri.com/t5/arcgis-pro-ideas/set-and-honour-timezones-in-pro/idi-p/1632995/highlig...
NathanShephard
Jumping into this discussion.  🙂
In ArcGIS Pro 3.6, we've added support for displaying date/time values for all time-zone-aware data in the map's time zone (whether that's from services with/without Preferred TZ, or local FGDB data with a layer-defined TZ).
Quick overview of the workflow:
  • Per usual, set time properties (inc. time zone) for individual layers in Layer Properties > Time
  • Then, either on the Time ribbon or in Map Properties > Time, set the map's time zone
  • Then, check on the option to "Display values in this time zone"
  • RESULT - all places where time-zone-aware content is shown (tables, attributes pane, time slider, etc), the values will be converted and shown in the map's time zone
  • The time zone being used can be seen in places like the hover-tip-help for columns in the table, and explicitly stated when editing values using the Calendar control.
More detailed information is available here:
The  similarly-described idea mentioned by RTPL_AU, above, has been marked as Implemented, so I am hoping the requirements listed above are also handled?  Hopefully you're able to move to Pro 3.6 and try it. If it looks good, please let us know and we will close this one, too.
Thanks!
-Nathan.
