Many/Most of the processes in ArcGIS Pro are accessible programmatically. Look at how the various tools/processes are used from a Server / Notebook / Model point of view.
From the tone of the UC plenary (I've only seen a few minutes here & there), Esri may look into better use of agentic AI going forward.
In some aspects that are apparent from the existing AI companion use in AGOL, it seems that Esri are looking at scenarios where users 'converse' with the application to achieve the outcome they need.
From an agentic and conversational UX point of view, the developers will now need to focus on three 'UI' environments:
As this developmental process evolves, I suspect Esri may get into strife keeping all three streams up to date & performant. They're already not in the best spot right now and they are only focusing on one of the three (in public versions, I may be off target by a wide margin and iPro 4.A will have a spectacularly good UI and great UX).
In addition, as we evolve our own agentic solutions, I foresee the way we will solve problems will diverge significantly.
Back to the Idea.
If the Pro UI gets Open-Sourced, I hope to see that others create task-specific, or focused UI solutions or combinations that leverage the very strong toolkit and ecosystem that Esri has built.
Leaving accessing these proprietary tools and processes via a new UI to suit your project, or your personal AI agent, to others, will create significantly more opportunities for Esri to focus on the core paradigm of creating tools that solve problems, store data, find data, etc.
Going back to science fiction movies, there are many events where a person discusses a design and the AI makes changes (Iron Man for one). My take is that the key to realising this ideal is that the UI has to be built to suit conversational instruction and result-driven visual feedback.
The current Pro paradigm of tools needing focus on a particular window/pane to determine a right-click context, having dynamic toolbars or many open panels, etc. does not look to be the most suitable for the best conversational experience.
I am sure there are smart people out there that will jump on the chance to make this a reality; but it will only work if Esri can build the AI and backend enablers rather than wasting time trying to figure out why Catalog doesn't sort files & folders the same way Windows does or how to create a better GP batch processing UI that can mimic what we had in ArcMap.
This is a complex topic I find very interesting.
Kudo (or not), give feedback, and tell us how you see this evolve over time.
Interesting idea. I think the ArcGIS Pro SDK could already be used to build a custom UI using AI tools. From the point of view of the support it would be a nightmare to allow all users to AI customise their default ArcGIS Pro UI. Esri could also no longer ensure ArcGIS Pro security, if everyone could modify it without actually knowing, what the AI (or User) is doing to the code.
I already see too many people trusting AI blindly...
@SimonSchütte_ct Interesting take.
The core to the Idea is the ability to make the UI do what we need it to do, and Esri focus on the glue needed to optimise the underlying tools for the agentic interfacing of the future.
I assume that some would use AI to make changes to the Ui - not the purview of this Idea to imply that using AI for coding is good or bad.
The security of the UI, as far as I am concerned, is based on the framework they are using. Being a .Net flavour, I don't think you need AI to make holes in it 🙂
Making it an Open-Source project would allow more/better specialists in the domain to have eyes on it. The number of bugs continually introduced don't give me confidence that internal-only review is optimal from that point of view.
Add to it the fact that single use AGOL organisations cannot deploy MFA or advanced log-in methods, the UI code to open a file browser is probably not the golden target in my opinion.
"I already see too many people trusting AI blindly..."
Exactly!!! I want to remove/disconnect the UI from the AI so that we can have control over what we use and do. A completely locked down ecosystem will mean that we have to consume the 'AI' in the UI that Esri determines is the best for us. I have one word: Ribbon... but AI.... 🙂
