I like your extended messaging in the geoprocessing window, but in the messaging the following message was present
Temporary data will be created in C:\Users\user\AppData\Local\Temp\ArcGISProTemp66476\s81164d47_6e4e_472e_9c75_5d5d03069b7
55,942 MB of temporary storage is estimated to be needed. 86,573 MB of storage is currently available.
I could not find any mechanism to change the location of this directory I look in environment variables and in the Project options
May we have a capacity to do this
To all I found the location
Cheers
2nd Update despite performing the change to local directory as above (and restarting program as stated)
When processing a distance allocation process I still got
Temporary data will be created in C:\Users\user\AppData\Local\Temp\ArcGISProTemp78368\sbb3a674e_b846_4b90_a68c_bb6f6e6de7a7
55,942 MB of temporary storage is estimated to be needed. 86,408 MB of storage is currently available.
Cheers
Hi Paul,
You can set a system environment variable to change the location the distance tools, and other tools that use parallel processing, write.
Distance Allocation help documentation:
Liz
This is documented in the help that Liz shared above.
This had previously been logged as a bug with technical support, and that bug was closed, guiding users to set the temp directory as a system environment variable that Pro respects: https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDExMjAyOQ==
[BUG-000112029: Unable to set the location of the temporary directory used by ArcGIS Pro.]
Please refer to https://community.esri.com/t5/arcgis-pro-ideas/enable-setting-location-of-temporary-directory-in/idi... This work is underway.
