I have been putting together a lot of ModelBuilder tools recently and I am finding it difficult to do error check when I reuse a model for a different purpose or have made a change and there are issues that are created down stream. Some of these errors with break the model, but a lot of times if there is an issue that will not break it, like a change in schema, it will only create a warning on the geoprocessing level and there is not notification on the model level.
I would love it if there was just an icon that showed that there was an issue with that particular section of the model so that I would not have to run the model to find out that it will not run fully due to a warning notification. #modelbuilder #debugging
