The little "P" for parameters is really handy. Why not have a similar visual indicator (maybe the green checkmark you see in the contect menu) that shows up for outputs destined for the map. It could help know if you have everything being added that you want and easily find ones you need to turn on/off.
It's not a green checkmark, but I just wanted to make sure you were aware of the filtering capability that can help show all outputs where 'Add to Display' is checked, and move to each...
Search and filter elements in a model—ArcGIS Pro | Documentation
I just wanted to share this in hopes that it might help you now.
Cheers
Good info, not near as intuitive but better than clicking them one by one..
Thanks!
