Maintain legend format when switching map frames
2824
7
08-13-2021 06:58 PM
Status: Implemented
SBrandenburg
New Contributor III
When you change the map map frame, you lose all the legend formatting. You go through the trouble of making a legend which can be quite time consuming, and want to recycle it with a similar map, but when you switch the maps in the map frame, the legend resets itself to the defaults.
Tags (1)
7 Comments
AubriKinghorn
We are working on legend styles, which will let you save legend formatting to a style and apply it to any map frame.
David_Brooks
Ive found a workaround to this. You need to cut the legend > relink the map frame > then paste the legend back in. Works for me
JenniferBorlick
@David_Brooks Brilliant! Thanks. Now to remember to do it.
SBrandenburg
The equivalent of a layer file, but for the legend. It would set all the formatting automatically, for things like font and font size for each class, spacing, indentation, alignment...etc. I am constantly changing my layouts, even when I set them how I want them in my templates. Doesn't seem to matter. ArcPro always is changing my layouts. Doesn't matter if I check sync fonts when adding new items. It literally does not matter. ArcPro will change your legend for you, in all the worst ways.
I would love an option when my map is ready to export to PDF, that I just apply all the legend settings all at once.
JeffBarrette
Good news.  At Pro 2.9 we are introducing the Legend and Legend Item styles.  There will be a gallery of styles to choose from when you insert a new legend or legend item.  The styles can be modified and shared like other styles in the Pro application.
Jeff - Layout and arcpy.mp teams.
SBrandenburg
Sweet that's great to hear Jeff. Legends are a very time consuming part of producing maps with ESRI software. Glad to see this is getting implemented.
KoryKramer
Implemented in ArcGIS Pro 2.9.  See Ideas in ArcGIS Pro 2.9 and go directly to 3:13 in the video.
