The current Locate Features Along a Route tool only locates features within specified search tolerance. This sometimes results in features being located along the wrong route. I would like to see the option to use a route identifier field in the input tabular data that would eliminate this problem. This way routes that are within the specified distance would have to also have the same route identifier as the input feature in order for the feature to be located.
