Improving the appearance of Grouped Layers in ArcGIS Pro Table of Contents
741
03-08-2022 08:22 PM
Status: Open
LindsayRaabe_FPCWA
Occasional Contributor III
Something that has annoyed me for a long time is the difficulty that I sometimes find with identifying where a set of grouped layers ends and a new layer/layer group starts. The below example shows a set of layers grouped together with individual layers both above and below the group. At a glance, it is hard to tell where the group stops though.
It would be great if an improvement could be made that somehow highlights what layers are grouped together. Maybe a line/bracket down the side of the tree showing the grouping, a faint bounding box or a slight change in the background shading to show groups?
LindsayRaabe_FPCWA_1-1646799174460.png LindsayRaabe_FPCWA_2-1646799426944.png LindsayRaabe_FPCWA_3-1646799653388.png
3 Comments
JohannesLindner
If a map has multiple levels of (group) layers, it can be hard to determine to which group layer a given layer belongs in the table of contents, because the indentation between the levels isn't big enough:
I would like the indentation between the different layer levels to be increased or to have an option to do so myself.
In my opinion, that would help clarifying the structure tremendously:
MarkLimbruner
The TOC needs totally reworked, too much space between items, the fonts and patches are way too big, ArcMAP had a much better-looking Table of Contents, one can barely tell what layers have been placed under a Group.
LindsayRaabe_FPCWA
@JohannesLindner idea of simply increasing the indentations is a good one. Clear separation between the check-boxes clears up the confusion. Overlapping check-boxes makes it too hard to discern where indentations align through the list.
