When we try to import changes from a delta file into a replica geodatabase:
arcpy.ImportMessage_management(in_geodatabase="ConnectionFile.sde",source_delta_file="PathTo/checkin.xml",output_acknowledgement_file="#",conflict_policy="MANUAL",conflict_definition="BY_OBJECT",reconcile_with_parent_version="DO_NOT_RECONCILE")
We get the following error message:
Messages
Executing: ImportMessage "ConnectionFile.sde" PathTo/checkin.xml # MANUAL BY_OBJECT DO_NOT_RECONCILE
Start Time: Wed Jul 27 16:34:57 2016
Executing ImportMessage...
ERROR 000582: Error occurred during execution.
The Geometry has no Z values
The workspace is not connected.
Failed to execute (ImportMessage).
Failed at Wed Jul 27 16:35:09 2016 (Elapsed Time: 11.36 seconds)
In our case this error message is caused by Geometric Network Default Junctions which have invalid coordinate values ( NaN 😞
<Record xsi:type='esri:Record'>
<Values xsi:type='esri:ArrayOfValue'>
<Value xsi:type='xs:int'>1206</Value>
<Value xsi:type='xs:short'>1</Value>
<Value xsi:type='esri:PointN'>
<X>NaN</X>
<Y>NaN</Y>
<Z>NaN</Z>
</Value>
</Values>
</Record>
Please provide detailed description, for example the ObjectID and feature class name of the
geometry in the error message
This idea was associated with ENH-000098480 which was marked as non-reproducible. If users are still encountering this issue, please contact technical support to investigate.
Thank you
