Similar button to Import... on the Symbology tab of the Layer Properties, but on the Labels tab instead.
Would allow you to Import Label Symbology from another layer in the map or a saved layer file. It would also be nice if it not only imported the label symbology, but also any Label Field expressions, SQL Queries, Symbol Classes, and Placement Properties associated with the layer you are trying to match.
While this isn't exactly what is being requested in this idea, in ArcGIS Pro 2.1 you can now copy label class properties and paste all, or some of them into another label class.
See the Annotation section around 3:15 in this video: What’s new in ArcGIS Pro 2.1 video | ArcGIS Blog
Kory,
Is there anyway to "resurrect" this Idea into ArcGIS PRO? I know you mentioned that we are able to copy label class properties now in 2.1 but I really think we need the equivalent of a .LYRX file for labels.
An example I'm working with today is standardizing Township/Range/Section Labels for various sized templates. I'd LOVE to be able to save a label just like a layer file and then import that into each template in order to assign the same properties to a feature in different templates. As it is right now I have literally had to write down my label properties for each template and then re-create them for each layout.
Serious Wayne's World here.... Shahah.... as if....
But4real, I was spontaneously brain farting but if we can bring in AutoCAD files with their own little files for text and/or characters, then why couldn't/can't we do the same thing with ArcGIS? Labels to a .lyr with the TEXT in it (especially if we have Expressions or SQL queries for the Label) and then import them back in to the shapefile or feature that we're using?
In Pro you can save text symbol styles and label placement styles. Easily shared between layers, maps and coworkers.
https://pro.arcgis.com/en/pro-app/help/mapping/layer-properties/save-symbols-in-styles.htm
The label expression and sql query can be saved out and shared as .lxp and .exp files
Hope that helps,
Wendy
Wendy,
Thanks for this but some of us Professionals are being reduced to interns at 50 and aren’t allowed to use Pro. (Bigger rant is why is it I should use Pro when the functionalities of ArcGIS are central to my projects?)
Ok, not to be snide but if you have some screen shots of this that would be nice.
Daniel T. Brenner
RESEARCH ANALYST I (GEOGRAPHIC INFORMATION SYSTEMS)
DIVISION OF RESEARCH, INNOVATION, and SYSTEM INFORMATION
Highway System Information and Performance
1120 N Street MS 38
Sacramento, CA 95814
(916) 657-4277
(510) 593-7547 cell
daniel.brenner@dot.ca.gov<mailto:daniel.brenner@dot.ca.gov>
“Consider the unconsidered.”
“Certainty is not a sure thing!”
Below are screen shots of saving label expression, sql query, symbol style and placement style
Pane 1 - this is the label expression tab. if you click the green arrow it will launch a dialog to save the label expression. when you go to use it for a new layer, cick the open file icon and load it up
pane 2 - this is the sql query tab. click the save icon to launch a dialog to save it. click the load icon to load it up on another layer.
pane 3 - this is the symbol tab. click the burger in the top right and click Save symbol to style. this saves the symbol to a style. you can then apply it to another label class using the gallery that is in the labeling ribbon
pane 4 - this is the placement tab. click the burger in the top right and click Save placement to style. this saves the placement to a style. you can then apply it to another label class using the gallery that is in the labeling ribbon
more help on styles can be found here
You can also create from scratch and manage your styles in the catalog view
Wendy,
Could you explain (if not too time intensive) what is going on here? I didn’t see anything related to a label expression or query?
I have seen Maplex and maybe it will help but given the rigorousness of what I am trying to do I have to wonder.
Maybe this will help.
Daniel T. Brenner
1120 N Street MS 38
(916) 657-4277
(510) 593-7547 cell
I put notes in the note above. hopefully they help.
Maplex will not help with the saving out and applying of properties as it is a high quality label engine. It will help get more labels on your map though.
here's a good place to start reading up on it
https://pro.arcgis.com/en/pro-app/help/mapping/text/label-with-the-maplex-label-engine.htm
Wendy
