I was following along with the instructions at How To: Convert AutoCAD DWG files to a GIS-compatible file geodatabase in Pro pretty well until I got to step 7 under Converting CAD annotation to geodatabase. In Pro, this is the 2nd page of the wizard, and the Import dialog doesn't allow for selecting the Annotation CAD feature class like ArcCatalog does.
Pro - the .dwg does not appear:
ArcCatalog - shows the DWG and components.
Did you ever figure this out? I have the same issue
@ShiraEllenson1 no, I've just been using ArcCatalog.
Hi all,
Tool unavailable. I also posted a question and an idea about this. Links below.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/appendices/unavailable-tools.htm
https://community.esri.com/t5/arcgis-pro-questions/import-cad-annotation-tool/m-p/1275802#M67627
