Using the hyperlink tool we should be able to open the folder directory. Currently it opens only if a document path is specified in a record. If a directory is specified then the hyperlink tool is disabled
Hello @AnandRao ,
This functionality is already offered in ArcGIS Pro. Please see this blog post from 2018 that discusses how Hyperlinks are supported in Pro: https://www.esri.com/arcgis-blog/products/mapping/mapping/the-power-of-the-pro-pop-up. It specifically references this functionality being available in Pro 2.1.
Also, here is the link to the Help topic about using hyperlinks in a Pro pop-up: https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/use-hyperlinks-in-pop-ups.htm
Thank you for your feedback.
