When drawing a line, i would like to be able to hold down the 'Shift' key to draw vertical, diagonal or horizontal lines, as is the standard in many applications.
Constraining to angles by holding down the shift key should also be enabled when moving objects in layout.
There are inferred constraints in ArcGIS Pro that I think help with this request https://pro.arcgis.com/en/pro-app/latest/help/editing/inference-constraints.htm Enabling the reference grid may also be helpful: https://pro.arcgis.com/en/pro-app/latest/help/editing/enable-the-editing-grid.htm
For users looking specifically for similar constraints when working with layout elements, please go to https://community.esri.com/t5/arcgis-pro-ideas/use-shift-key-to-constrain-movement-of-layout/idi-p/1... and add your support by giving it kudos.
Thank you
