Georeferencing in ArcGIS Pro - How to use the 'Viewer' tab like in ArcMap
665
08-14-2024 12:02 PM
Status: Needs Clarification
BlendaRodriguesCarvalho
In ArcMap, when I needed to perform georeferencing, I used the 'Viewer' tab so that I wouldn't have to use 'Zoom to Layer' on the layer when adding control points. In ArcGIS Pro, I am unable to replicate this process. I suggest adding this feature, as it simplifies the workflow when georeferencing images:
1 Comment
KoryKramer
@BlendaRodriguesCarvalho
In ArcGIS Pro you can open multiple views of the same map and you have options to do things like Link Views, Link Cursors, and so on.
To create a second view of the same map, just Open the map a second (or third, or fourth...) time.
Does that help with what you're trying to do?
