Agreed who chose and applied that terrible naming convention "_V" ? In our shop we use a similar naming standard like the author and it is annoying to hack the geodatabase to change the names of all the views. This causes a complete mess if unregisteration occurs causing a bunch of work that really should be controlled.
Why not add a DBTUNE parameter that we can control? Isn't that what this is configuration is intended for...
Also agreed on the visibility of these items in Catalog, it was nice to be able to see them in 10.0 why are removing things that were just fine? Or at least explain your reasoning for doing so in release notes if this is such an improvement.
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
