Fix this Pro Bug: Import XML is missing schema preview
1037
09-15-2018 11:29 AM
Status: In Product Plan
ThomasColson
MVP Frequent Contributor
In Arc Map, when importing a XML workspace document, if the XML contains a feature class of the same name, not only does it append the name, it give you the opportunity to rename it, in addition to showing you a sort of preview of the schema. In Pro, no such thing, just this useless message:
WARNING 001163  C:\Users\username\Documents\ArcGIS\Projects\MyProject30\PRO_TEST.sde contains existing datasets. These datasets will get created with new names.
1 Comment
ThomasColson
Disappointed to not see this addressed in 2.3. Why was it removed in the first place?
