Find and replace with nothing in Pro attribute table
331
6
01-21-2021 12:41 PM
Status: In Product Plan
DanielleKulas
Occasional Contributor III
Thank you so much for adding the Find and Replace function to the attribute table in Pro, it's super useful! In ArcMap, we had the ability to find and replace contents of the attribute table with nothing if we wanted to, but that option is not available in Pro currently from what I can tell. Any way to bring this back?
My use case is that I'm removing some unwanted HTML from my attribute table. When I set up the find and replace, the arrow(s) are inactive with no value in the Replace box. As a workaround I've been replacing with a space but it would be better if I could just remove the HTML altogether as I could with ArcMap.
Thanks for your consideration!
6 Comments
DanPatterson
two double(single) quotes is equivalent to an empty string eg ""
it is not the same as None since there is only one None
DanielleKulas
Oh, sorry I should have mentioned that I tried that. It put the "" in the attribute as two quotes though:
Before
After
DanPatterson
hmmmm  Definitely a good idea!
in the interim a little field calculation
obviously replacing your field name for More_Junk but leaving the enclosing ! !
DanielleKulas
Thanks! I knew there must be a better workaround! I appreciate it.
KoryKramer
LakshmiSankaran
Yes, please do bring  back the ability to replace characters in the entire table with a blank as is available in ArcMap. We sometimes have to eliminate all special characters in a table in all the fields. This is one step in ArcMap, but "calculating" a replace in multiple fields is too time consuming.
Thanks
Lakshmi Sankaran
