Export to IFC
2124
6
02-05-2022 01:14 AM
Status: Open
OleSeidel1
New Contributor III
I need to export 3D data to IFC.
For example I created 3D buildings from drone imagery and now I'd like to give this data to an AEC company which is using Revit or ArchiCAD.
Or I generated a topo surface or elevation iso lines which I want to export to a 3D CAD environment.
6 Comments
KoryKramer
It looks like the Data Interoperability extension supports writing to IFC. https://www.esri.com/en-us/arcgis/products/arcgis-data-interoperability/supported-formats Can you check me on that @BruceHarold ?
AmeliaBradshaw
Hello @OleSeidel1
Thank you for posting this Idea! As Kory and Bruce could confirm, one can write to IFC using the Data Interoperability extension. Would this work for you, or would your Idea request to integrate this functionality into ArcGIS Pro, outside of an extension?
OleSeidel1
Thank you all for getting back to me so quickly.
We will evaluate this within the next couple of days and give you feedback.
Ole
Oberbossel
we have the same Problem. The is no exampla for convert a multipatch into the IFC-Format.
Jens
DA_BIM-GIS
Hello @Oberbossel and @OleSeidel1
Here is an example of of FBX to IFC 2x3, but the principle works for fGBD (multipatch)
cc @BruceHarold
