Expand the export types for modelbuilder when exporting to graphic
249
02-07-2020 04:12 AM
Status: Open
DuncanHornby
MVP Frequent Contributor
So the latest release of ArcPro 2.5 now has the ability to export the model as an image, a function that ArcMap has.  This is a most welcomed addition to ArcGIS Pro and something I would certainly use regularly. If only...
So the current options are pdf or svg as export formats.
As 99.99% of the time I will want to include the image in a word document as part of a report I am very unlikely to use PDF so this leaves me with the SVG format.
  • SVG does not import into Word
  • SVG does not import into powerpoint
  • SVG does not import to Google Documents
  • SVG does not open MS paint
You starting to see a pattern here...
Why on Earth have you chosen a format that none of the major word processing applications can even read....?
No one should need to be having to use a third-party software to convert the output into a format that their word processing can read. ArcMap was capable of exporting to a variety of formats.
Please add PNG, BMP, GIF to the export types.
3 Comments
KoryKramer
Word should work...
DuncanHornby
What version are you using? My work machine is this:
JamalNUMAN
Is the “print setup” available in 2.5? or developed in 2.6?
