Easily identify features with attachments in ArcGIS PRO
172
09-17-2019 08:00 AM
Status: Open
Environnement_1Lausanne
Hello,
It would be very useful to be able to very simply identify which features have attachments. It could be a column in the attribute table with a boolean TRUE / FALSE value for the ATTACHMENT field.
Even better, an additional column saying how many attachments are linked to each features.
Thanks in advance
4 Comments
KoryKramer
While not entirely built-in, you should be able to accomplish this using some guidance from Visualize your attachments in ArcGIS Online with Arcade
It looks like you would leverage the Attachments Arcade function Data Functions | ArcGIS for Developers
Since this was introduced in Arcade 1.6, make sure you're using ArcGIS Pro 2.4.x: Version Matrix | ArcGIS for Developers
LeviCecil
Couldn't you just write a Python function to create this field and then populate it with a true or false based on whether or not there is an attachment?
Hi Kory, thanks a lot. We'll have to upgrade our ArcGIS PRO version to use the function.
I tried on ArcGIS Online and it seems to work fine with Arcade in test mode but when I want to apply the changes, it tells me "unable to append the data". Do you have any idea why ? I can edit the feature layer.
Yes, I could indeed but I had read that ESRI had done a few devs in this direction so I wondered if a tool or function was about to be released. It is indeed the case according to Kory's message.
