Easily Change ArcSDE Connection Parameters and Update MXD
2094
12
12-11-2012 06:29 AM
Status: Open
RichardA
When one of the parameters in your ArcSDE connection changes (i.e. expired password, changed database server, etc.), it would be nice to have an easy way of updating an MXD with the new parameters.  If you have a lot of layers in your MXD (a map document to create a web map service could have upwards of a hundred different layers pointing to the same ArcSDE server), opening the MXD in ArcMap can take hours.  Even trying to update the connection params via "Set Data Source" in ArcCatalog sometimes hangs.
12 Comments
MelissaNorthey
Arne - no issues encountered since.  I highly recommend it.  We also use this for a license server.  Now I can move the license server to another box and the only ones I have to worry with are those outside of our network that need the IP address.
Arne_Gelfert
Thanks for the heads up!
