Displaying the coordinates with plus/minus notations instead of N-S-E-W designations in ArcGIS Pro
1814
09-08-2019 01:38 PM
Status: Open
JamalNUMAN
Legendary Contributor
It would be useful to show the coordinates with plus/minus notations instead of for N-S-E-W designations i in ArcGIS Pro (as they used to be in ArcMap)
3 Comments
KoryKramer
Note that this can be controlled in the Options  > Units > Location Units for decimal degrees, etc.
What coordinate system is your map in, and the data, where you're relying on negative units?
JamalNUMAN
Thanks Kory.
What I wanted here is to replace the (N-S-E-W) with (+/-) the same way it used to be in ArcMap. Is this still possible with the options there?
JamalNUMAN
This is not doable even in Pro 2.5
