It would be helpful if we could disable all default locations/workspaces/names for all ArcGIS Pro projects and geoprocessing tools as an optional setting.
In other words, I'd prefer it if a file path/folder was never auto-populated for GP tools in ArcGIS Pro. I always want to be forced to browse to a path/folder to ensure that it is correct.
@Bud Can you give us some guidance on how you want this to be implemented?
Hi @JonathanNeal,
Thanks for asking.
I agree with this, although for a different reason. The autogenerated names are almost never what I would call the output, so every single time I need to first delete the name, then type my own. This adds a huge amount of friction to what should be a simple process. (Add to that the name field going from showing the name to showing the whole file path on selection, another UX issue).
I'm less interested in having to pick the file location each time though, so two separate options would be better. One to stop autogeneration of names, and one to force location selection.
Thanks.
