Hi Russell
The Defense Mapping TLM North Arrow has configurable properties that can be adjusted to the users needs. However, this element does have minimum angles as defined in the related mil-spec requirements. If you need further adjustment, the element can be converted to a graphic and modified manually. You might also want to create your own element as needed. More info here...
Create Declination Diagram (North Arrow) with Python | ArcGIS Blog
https://www.arcgis.com/home/item.html?id=dd664ce915214390b8cb8babb09a84bd
