Data Driven Pages dynamic text - have it respect coded value domains
693
04-04-2012 12:58 PM
Status: Implemented
BrentEstrem
New Contributor III
I'd like to see the "dynamic text" feature enhanced in Data Driven Pages.  It would be nice if it respected attribute field domain values.  Currently, if you add dynamic text that references an attribute field it retrieves the code, rather than the domain value.
For example, if you have an attribute field called "Status" with a corresponding coded value domain associated with it like the one listed below...
1 = Proposed
2 = Active
3 = Retired
When you add a dynamic text tag to the data driven page, i.e. <dyn type="page" property="Status">, it reveals the code rather than the domain value.   It shows "1" instead of "Proposed".
3 Comments
CoryWilliams
It could be nice to have this as the default... but you can select the domain value:
<dyn type="page" property="attribute" field="<Field Name>" domainlookup="true"/>
I came across this just yesterday because I was having the same issue.
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s900000039000000
Maybe swap it around (so you can still select the coded value if needed?)
Hope this helps in the interim.
AubriKinghorn
AubriKinghorn
This Idea has been implemented in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
