In Geodatabase Designer you are able to extract geometric network, topology, relationships, etc to XML.
The XML export can be used to restore the a geometric network, topology etc. with the same setup as the original.
This is a really usefull functionality, but why is Road Networks omited from this functionality?
Please include the same XML export/import of Road Networks in Geodatabase Designer.
Best regards
Kristoffer
Informi GIS A/S
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
