Copy clause with Select by Attributes
736
12-02-2020 03:42 PM
Status: Already Offered
EllenSaxon
New Contributor III
When using the the Select By Attributes wizard allow the duplication/ copy & paste of clause to reduce the actions required when selecting multiple values from the same field.
3 Comments
by Anonymous User
Hey Ellen, this is a great question,
What we could do in this situation is select "Includes the Values" from the operator drop down as per below:
This will then allow us to select multiple values from the one field, as per below:
I hope this helps!
Regards
@KeiranBray
KoryKramer
With the need being "to reduce the actions required when selecting multiple values from the same field" this is possible by using the includes the value(s) operator as helpfully pointed out by @Anonymous User
Thank you!
EllenSaxon
That will do the trick. I didn't see anything like that in my googling.
Thank you @Anonymous User & @KoryKramer!
