Change of Map Frame - Set to Bookmark Instead of Zoomed to Full Extent
1405
6
02-08-2024 12:38 PM
Status: Implemented
SheriNorton
I often use a duplicated layout, then change the Map Frame source. When this is done the scale of the map zooms to the full extent of the data. I wish there was an option for Layouts to set a default extent or Bookmark of the respective Map. This saves time waiting for the layout to finish drawing (particularly if there's an underlying ESRI basemap so it's literally drawing all our data zoomed out to the entire world!) before activating the Map Frame and choosing the correct scale and location (usually by picking a saved Bookmark.
6 Comments
AubriOtis
Thank you for your idea! While this doesn't do exactly what you described or work in all situations, map frame constraints can be helpful in making sure all data doesn't draw when you change a map frame. See this blog to learn more about why repathing a map frame works like that and how map frame constraints can help https://www.esri.com/arcgis-blog/products/arcgis-pro/mapping/map-frames-and-the-magic-of-map-frame-c....
SheriNorton
Thanks AubriKinghorn! I never thought of tweaking that Display Option-> Constraint option first before changing the Map Frame. I still think an overt "adhere to Bookmark" would be a great time saver, though.
MErikReedAugusta
Somewhat-related, I just posted an Idea that sparked from me running into a similar issue:
https://community.esri.com/t5/arcgis-pro-ideas/tool-or-function-to-easily-duplicate-amp-fork-a/idi-p...
tl;dr I frequently find myself needing two almost-identical layouts.  I'll build the first one, duplicate the layout, duplicate the map, and then re-point everything on the second one and finally make whatever changes are different between the two layouts.  Very tedious because of little headaches like the one addressed by your idea.
I would love to be able to tell a Layout, "Hey, I'm pointing you to a new map.  But everything is actually the same under the hood, so just trust me and repeat exactly what you were displaying before with the old map.  No resetting things to the default!  It'll be fine, and I'll fix whatever breaks manually!"
AubriOtis
AubriOtis
AubriOtis
In ArcGIS Pro 3.4 changing the map in a map frame now remembers and applies the previous map extent, as long as the coordinate systems are the same. If the coordinate system of the new map is different than the previous map the map frame draws the set custom make extent, the extent of the layers, or the default map extent (in that order, depending on what is available).
Go to Your Ideas in ArcGIS Pro 3.4 to see other ideas implemented this release and check out the What's New help to learn about everything that is new and improved in ArcGIS Pro 3.4.
