Change Configure Pop-Ups Field Options Layout
402
12-16-2020 11:11 AM
Status: Already Offered
by Anonymous User
Not applicable
A lot of the data I work with has hundreds of fields. When sharing this information with the public, I routinely configure layer pop-ups in order to only show the most relevant information.
Selecting Configure Pop-ups:
When configuring lots of fields, the first thing you see is this:
Only when you scroll all the way to the end, do you actually get to the checkbox to turn off using all visible layers.
Instead of having to scroll all the way down to this setting, it would be quicker and more effective if this checkbox was all the way at the top of this pane above the "Display - Field Alias (Field Name) line".
Tags (1)
2 Comments
KoryKramer
Thank you for submitting this idea @Anonymous User .  I think you'll be happy with ArcGIS Pro 2.7 which should be available... today!
Also check out Ideas in ArcGIS Pro 2.7: Something to Celebrate and what's new in ArcGIS Pro 2.7!
by Anonymous User
Thank you so much! I just downloaded 2.7 and I see the change. Great work.
