Cartographic Representations – Automatic changes in representation
267
09-27-2010 09:49 AM
Status: Open
Jean-GuyChauvin
Currently, if a representation is done based on a classification of pipe diameter ranges for example, if the diameter of pipes changes to a diameter of another pipe classification range, the representation will remain unchanged and will show the pipes to look as if they are still in the same pipe size classification as before the change. This sort of behavior is a real problem and there should be a way to have the representation change automatically based on a change in its represented attribute.
Tags (1)
