Bulk edit tool for metadata
2487
9
12-06-2011 09:57 AM
Status: Open
JasonBarney
New Contributor II
There needs to be a way to do bulk edits across multiple feature classes. I have custodians within my organization who manage many feature classes. Its a pain to go and update the SAME contact info across each feature class. Should be able to apply a template which is common to all the feature classes, and then just go in and update the relevent information specific to each feature class.
9 Comments
by Anonymous User
Excellent suggestion! I struggle this with over 50 feature classes to update with the same contact information.
JenniferBorlick
We have feature classes in the hundreds. Although, I guess I don't have to be the one to worry about changing the contact information. It would be the person that would come after me that would have to deal with it. :)
ChrisFox
Below is a help document topic that discusses how to accomplish this workflow:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//003t00000026000000
JasonBarney
I appreciate that there is a backend solution, but having worked with XSLT, this isn't a very client friendly approach. I work in a large municipal/local government organization, and the onus would be on a developer to modify the stylesheets and run it through the GP tools, and that's specific to one custodian. We have dozens of custodians responsible for hundreds of feature classes. Getting custodians to maintain metadata is hard enough as it is.
JordynMitchell
I don't understand why there still isn't a user configurable pick list for editing metadata contacts, and other common repeated elements when editing metadata.
I also don't like how when you use a template that it overwrites all existing metadata - what if you just want to change one or two things, and do that in batch mode?  The NPS metadata tool did this pretty well.
You should be able to select a group of featureclasses, and be able to change just selected attributes in the metadata in batch mode....
RichardHowe
Seems like this should be pretty easy to add-in and would save lots of time!! Let's see it ESRI!
VictorKing
XTools Pro has exactly what you are looking for
Batch Metadata Editing.
http://www.xtoolspro.com/tools.asp#gu20
BruceGodfrey
jcokin1
The following ideas have all been merged together as of 7/26/2017. Do not know why the scores have not been summed up yet.
Just FYI
1.Bulk edit tool for metadata (Primary / Lead Idea)
https://community.esri.com/ideas/4726
Vote Score = 700
2.Metadata search-and-replace (Merged)
https://community.esri.com/ideas/4014
Vote Score =  290
3.Batch Update Item Descriptions when necessary (Merged)
https://community.esri.com/ideas/5919
Vote Score = 110
4.Batch Editor for XML Metadata for Universal Changes (Merged)
https://community.esri.com/ideas/9492
Vote Score = 10
