Hello,
It took me a long time to figure out how to correctly edit a topology in ArcGIS Pro. There are a few parts that made the experience more confusing that it should have been.
First, It took me a while to find the official documentation located at https://pro.arcgis.com/en/pro-app/latest/help/editing/introduction-to-editing-topology.htm Even then the documentation weighted editing edges instead of vertices.
Second, When I did have a topology on I saw the modify edges tools,furthermore the tool as labeled "select and edge" I did not want to select an edge, I wanted to select a vertex.
Third, When I opened "select an edge" I noticed that the vertices were in purple so I figured I had the correct tool! However, when I tried to move the purple vertex nothing happened which reinforced my confusion. I was not able to move the vertex in a topology until after I double clicked on the vertex.
Thoughts:
For the tools that can interact with a topology please consider the following changes (This example is for the Edit Vertices tool):
1) Change the option to select "Features or Edges" to "Feature or Topology." When not using topology this particular tool can only modify a single feature at a time so the heading should be singular. When editing a topology I personally thing the heading should be "Topology" not "Edge". This would clarify the functionality for myself and perhaps others, not to mention what happens if a user wants to edit stacked points that are in a topology as there are no edges.
2) Once the tool is opened with modify Edges (Topology) selected we are told to select an edge. The tool opens up and we can select an edge. However we can also select the vertices as well. Similar to previous I do not know if "Select and edge" is appropriate. Is there space to specify "Select and edge or vertex"?
3) When I hovered over a point I noticed it was highlighted. I tried moving it but nothing happened. It was not until later that I realized that I needed to double click on the highlighted purple point so that it would turn into a green box which could be moved around. Is it necessary to have an additional step to switch from the highlighted purple circle to the green box?
4) Maybe it would be useful to add an example of how to edit a shared vertex within the documentation?
Thanks!
