ArcGIS Pro Table of Contents Filter- Visibility Range Filter
563
02-15-2021 09:44 AM
Status: Implemented
Amanda__Huber
MVP Regular Contributor
Please add a Table of Contents filter for layers' scale visibility. Ideally as a user zooms in and out of the web map layers set at that visibility scale would show up in the TOC. This would improve the multiscale map building workflow.
Currently there is a "Visible" option (which I initially thought did this by the name and I was excited) but this only displays TOC items checked/vs unchecked.
Thank you for your consideration,
Amanda
2 Comments
KoryKramer
There will be a new filter in the Contents pane coming in ArcGIS Pro 2.9 called 'Visibility range set'
It will filter the Contents to only show layers that have a visibility range applied.
KoryKramer
