ArcGIS Pro Project Notes Window
476
05-19-2021 01:51 PM
Status: Open
EricBushee
New Contributor II
It would be great to have a place in ArcGIS Pro to record notes and documentation about a project. It could be as simple as a notepad-like space in a separate window, accessed in the View ribbon. Notes could be typed in and double as a running history of the project. We often have multiple users accessing the same .aprx, and it would be helpful for them to record what they did, and why they did it, for the next user. It would also be helpful when you open a project two years later and try to remember what exactly happened. Separate Word or notepad files can always be made and put into the project folder, but once you start adding additional programs someone has to open, they are less likely to actually do it. With the current ArcGIS Pro architecture, it seems like it could be easily implemented as an additional window.
4 Comments
DanPatterson
How about a notebook in Pro
Notebooks in ArcGIS Pro—ArcGIS Pro | Documentation
You can use Markdown for documentation and export to a variety of formats.
Your notebooks are available with the project and for others
EricBushee
Yes, thanks, that is a possible solution. Ideally it would have more of a text box structure to it (like what I'm typing into here for this), but a markdown would work as a place to jot down notes.
NaicongLi
Hello Eric,
Thank you very much for your suggestion.  Have you tried to use the Description field in the project’s metadata to record such notes?  You can do this in the Catalog view: with the Project node selected in the Contents pane, click the Edit button on the ribbon, Catalog tab:
This will open a metadata view, where you can enter various types of information about this project – title, summary, keywords, description… The Description field offers some simple formatting functionalities, where you can keep your working notes, or any notes about the project (as well as the more formal description for this project).  Click Save and close the metadata view when you are finished editing for the time being (if you just close the metadata view, you will be prompted for any unsaved changes):
Once saved, your notes in the Description (as well as in other metadata fields) will appear in the Catalog view whenever Project is selected in the Contents pane:
Of course this means that, if later you want to share this project externally, you may need to clean up the metadata Description field to delete any notes that you do not want to share externally.
For more information on how to view and edit metadata in ArcGIS Pro, please see https://pro.arcgis.com/en/pro-app/latest/help/metadata/view-and-edit-metadata.htm .
We would appreciate more feedback from you regarding this topic, about whether using the Description field of the project metadata would satisfy your needs.  Thank you again for your suggestion.
EricBushee
Thanks, I have considered that. We typically try to keep the metadata a little more concise, and my thought was to have a place for a running history of the project, which might tend to get a little long in the metadata. Thanks for replying, though, I appreciate it.
