ArcGIS Pro 2.6: A geoprocessing tool to combine two tables,
174
6
08-09-2020 12:58 AM
Status: Open
JamalNUMAN
Esteemed Contributor
It would be great if we got an out of the box geoprocessing tool that combines two tables. I’m aware of that such tool could be available but I wanted this tool to be built in
In the screenshot below, I wanted to combine the attribute table of P1 with the stand-alone T1 to produce the stand-alone table T2
6 Comments
JamalNUMAN
Is this planned in 2.8?
KoryKramer
Hi Jamal,
The status will be updated if and when it is being considered.  A change to Under Consideration or In Product Plan will indicate movement on our side as described in the ArcGIS Idea Statuses document.
JamalNUMAN
Thank you.
Does  the number of Kudos for an idea represent the votes\points?
DanPatterson
Yes
KoryKramer
Hi Jamal. This link explains kudos being votes.  There is also a lot of other good information in here about ArcGIS Ideas: https://community.esri.com/t5/community-help-documents/frequently-asked-questions-about-arcgis-ideas...
I hope this helps!
JamalNUMAN
Thanks Kory
