ArcGIS Pro 2.4.2: Why the ArcGIS Pro creates gdb and tbx by default as new aprx file is created?
1719
10-28-2019 11:17 PM
Status: Under Consideration
JamalNUMAN
Legendary Contributor
I’m aware of that there is an option to disable creating gdb and tbx as new aprx file is created. However, I suggested that these two options are disabled by default as the ArcGIS Pro is installed in fresh machine
4 Comments
NaicongLi
NaicongLi
Hello @MicheleH1_DNReply, @DavidDurst, @LynnCarlson__GISP, @JamalNUMAN, and everyone,
(This is a response to this idea thread and to https://community.esri.com/t5/arcgis-pro-ideas/stop-recreating-missing-geodatabases/idi-p/1010302 and https://community.esri.com/t5/arcgis-pro-ideas/add-options-on-create-new-project-dialog/idi-p/928765.)
We have been listening to your suggestions and comments, and we understand that you have workflow disruptions connected to this aspect of the architecture of ArcGIS Pro.
We have in fact been exploring solutions for this for some time, but unfortunately haven't yet found one that would not have a negative impact on functionality, without fundamental changes of ArcGIS Pro’s architecture. From its initial design, an ArcGIS Pro project has three fundamental properties that must be specified – project home folder, project default geodatabase, and project default toolbox. They are there to ensure that when you perform an operation, the output always has some place to go, even if you did not specify the location. These requirements have been there since day one as a built-in assumption for many operations. Their absence could cause unexpected and bad behaviors in ArcGIS Pro. This is the reason why ArcGIS Pro requires their presence during the creation of a new project, and auto-regenerates them when they are lost.
We agree with you all that we need to provide more flexibility in how the default geodatabase and toolbox are handled. Some of you have proposed alternative ways to handle this, for example:
  • ArcGIS Pro does not generate a default geodatabase and toolbox when creating a new project.
    • For the reasons above, this is unlikely to happen, at least not in the near future.
  • At the project creation time, allow users to specify an existing geodatabase and toolbox to be used as the project default geodatabase and toolbox.
    • This is indeed a direction that we are considering.
  • When the default geodatabase or toolbox is missing or broken (which could be made to happen when the project is closed, or while it is open, if you manipulate the default geodatabase or toolbox in File Explorer instead of in ArcGIS Pro), have ArcGIS Pro prompt the user to create or select one. It’s been suggested to have this happen on project reopening, or when a Geoprocessing tool is about to run, or when the project is being saved.
    • In all cases, this would require blocking all the operations in the UI until the default geodatabase or toolbox is restored, a state that many users would not want.
We agree with you that it is annoying to see default geodatabases and toolboxes regenerated after you deliberately deleted them in the File Explorer. We will continue to look for a good solution that would not cause major impacts on ArcGIS Pro’s operations, and we are keeping this idea thread open. In the meantime, however, given the current constraints we have, the best thing to do is to NOT manipulate default geodatabases and toolboxes in File Explorer. In fact, managing your items inside ArcGIS Pro instead of File Explorer has always been the recommended practice, even for nondefault geodatabases and toolboxes. If you want to use a different geodatabase as the project default geodatabase, please use the following workflow:
  1. Add to the project the geodatabase that you want to be the default one (or create a new one). Rename it as needed.
  2. Right-click it and click Make Default.
  3. Delete, or remove the original default geodatabase in ArcGIS Pro if you do not want to use it in the project.
Use the same workflow to change the default toolbox.
One side point, in case some people are not aware of this option when creating new projects: instead of letting ArcGIS Pro create a default geodatabase and toolbox, you can designate a pre-existing geodatabase and toolbox for all new projects that you create from here on, by using the settings in the Options dialog (General tab, Create projects section). Note that you can change these settings any time and as often as needed.
Again, we are keeping this idea thread open and will continue to look for a good solution, while balancing it with our other priorities.
Thank you all for contributing your comments and suggestions.
JamalNUMAN
Thank you, NaicongLi, for the clarification.
I observed that the "Save As" tool has two scenarios:
  • If the project has not already been saved, then the .aprx file will be compulsorily stored into a folder.
  • If the project has already been saved, then the .aprx is saved as a standalone .aprx file without the need to create a folder (similar to the experience with .mxd files).
We need to have the option to save the .aprx as a standalone file without the need to have folder, toolbox, or gdb created!
Despite these steps, the .aprx is not displayed in the catalog (this issue has already been reported, and an idea has been created).
