ArcGIS Pro 2.4.2: How to display the full path of the aprx file on the title bar?
2236
10
11-01-2019 04:16 AM
Status: Implemented
JamalNUMAN
Legendary Contributor
It would be great if an option is made available to display the full path of the aprx file on the title bar. For example, this option is available in AutoCAD
10 Comments
JamalNUMAN
No sure regarding the status on this idea
KoryKramer
Hi Jamal.  The status of this idea is currently Open.  See  ArcGIS Ideas Submission Guidelines and Statuses - Esri Community
NaicongLi
JamalNUMAN
ArcGIS Pro 3.0: An option to display the aprx path (location on the drive) on the title bar,
It would be great if we got an option to display the aprx path (location on the drive) on the title bar.
This option is already available in AutoCAD and FME, for example
DanPatterson
JamalNUMAN
JamalNUMAN
My bad. I forget myself that I have already posted this idea long time ago!
NaicongLi
NaicongLi
Hello @JamalNUMAN,
Thank you very much for your idea.  In ArcGIS Pro 3.4, the project title has a dropdown, which will show you the path of the project .aprx file (with middle ellipsis if the path is long), the last modified time of the project, and a button for copying the path easily:
We hope this solution satisfies your need.
Thanks you again for your input, and we look forward to more of your suggestions!
NaicongLi
