It would be handy if, in ArcCatalog, the tab and sub-tab you were last on stayed active when you click on a different feature class. Currently, it stays on the proper tab (Metadata, for example) but if you're on the Attributes sub-tab under Metadata and click another feature class, it takes you to the Description sub-tab. It would definitely be more convenient if it stayed on the tab you were last on....
