ArcCatalog Geodatabase Connections (Direct/Application Server) options
327
12-21-2012 08:26 PM
Status: Closed
EmadAl-Mousa
Occasional Contributor III
Currently when you try to create a gedoatabase conenction in ArcCatalog 10.1 you only have the option to direct-connection with multiple diferent DBMS systems (DB2,Sql Server, Oracle,..etc). It will be more effective if the end-user will have another option in the drop down list with "application server" option. especially, if the current infrstructure being used is a  3-tier architecutre. This will be easier in work and administration than using tooleset
Create ArcSDE Connection File (Data Management)http://resources.arcgis.com/en/help/main/10.1/index.html#//0017000000pt000000
1 Comment
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
https://community.esri.com/t5/data-management-ideas/arccatalog-geodatabase-connections-direct/idi-p/...
