When adding a Map Service Layer, being published from ArcGIS Server, to ArcMap allow users to select features, open the attribute table, and edit the symbology for an individual layer within the Map Service.
Some of this might be possible using the WFS Capability of a Map Service and the Data Interoperability Extension but this should be part of the core capability of an ESRI Map Service and ArcMap. Uses should not need to have an extra extension for this capability. Also the WFS Capability can be very inefficient with large datasets.
These capabilities also go along with being able to add a Definition Expression too.
http://ideas.arcgis.com/ideaView?id=0873000000088alAAA
