Allow extent changes using bookmarks without requiring "Activate" on map frames
569
06-23-2021 03:37 PM
Status: Already Offered
MollyBarth
New Contributor III
When making a layout I am allowed to "zoom to layer" within a map frame without activating the map frame. However if I want to change the extent to that of a Bookmark, then I have to activate the map frame.  The need to activate to use Bookmarks seems unnecessary and significantly slows down workflow.
3 Comments
KoryKramer
Hi @MollyBarth and those who have voted on this idea...
I think we'll need some clarification to understand what is being requested.
It is currently possible to use bookmarks for a map frame in a layout without activating the map frame.
 This is also described in https://pro.arcgis.com/en/pro-app/latest/help/layouts/work-with-a-map-on-a-layout.htm
Can you clarify what the idea is asking for?
Thank you!
MollyBarth
Thanks @KoryKramer  I didn't even know that was possible. I stand corrected.  Feel free to mark this closed.
KoryKramer
Awesome!  Hope that helps your work!
Cheers
