In ArcMap, when you right-click in the Catalog pane you had the option to create a composite locator. While the option to add a locator is in Pro, the option to create a composite locator is not. You can still create a composite locator, but only by using the geoprocessing tool.
ArcGIS Pro:
ArcMap:
In ArcGIS Pro, the new > locator option launches the Create Locator geoprocessing tool. Are you just looking for a shortcut to launching the Create Composite Address Locator tool instead of going to the Geoprocessing pane?
