Rather than choose File->ShareAs->Service to publish all the layers in the map document, add additional functionality toallow a user right-click on a single layer in the TOC to publish only that layer.
ArcGIS Pro has the right-click a layer > Share functionality.
Since Pro has this functionality already, I highly doubt that ESRI would incorporate this functionality into ArcMap as that software is slowly being phased out and ESRI is mostly in bug fix mode with ArcMap.
Thank you for submitting this idea. We recommend using ArcGIS Pro which currently supports the requested functionality.
