Your ArcGIS Pro Update (May 2025)
1581
05-13-2025 01:39 PM
CaitlynNorth
We’re Excited to Share the Latest Updates in ArcGIS Pro 3.5 with you!
We understand the importance of having high-quality, reliable tools for your work, and it's a priority for us as well. This release not only introduces new features but also enhances the tools that you already use to make them more efficient and effective. Whether you're streamlining complex workflows, collaborating on ArcGIS Enterprise, or speeding up model building, this release is filled with improvements that you'll want to start using immediately.
Here is a quick look at some of the highlights:
  • Work better together: Save your ArcGIS Pro projects directly to your ArcGIS Enterprise portal, so teammates can access, edit, and save changes—no matter where they're working from.
  • Reduce manual entry: Speed up deed mapping with the new COGO Reader. Just upload a PDF or image and let COGO Reader automatically extract and plot courses for you.
  • Edit with confidence: Customize the appearance of vertices, nodes, and more as you edit with a new command that helps you quickly move through your QA/QC workflows.
  • Build models faster: ModelBuilder now includes semantic search so you can ask everyday questions like "How do I loop through rows?" and get results that match. The new Suggest Tool capability also recommends the next step based on your workflow—saving you time and clicks.
  • Improve metadata quality: Access the same metadata editor used in ArcGIS Online and ArcGIS Enterprise—now built into ArcGIS Pro. Enter essential information using a simplified interface and rely on built-in validation to track your progress.
These are just some of the recent advancements made by the ArcGIS Pro team. Read the blog to discover even more, such as location-based definition queries, symbols as point markers in line charts or scatterplots, and dual scale bars in your layouts.
Check out more here
3 Comments
Contributors
