Parcel Fabric Local Government Model GBD Feature Class Deletes
648
10-17-2023 12:13 PM
MarkWasdahl1
Environment: ArcGIS Pro 3.1.3.
Original Local Government Model, Parcel Fabric, includes Feature Classes (PLSS_Quarter_Section, PLSS_Quarter_Section_Lines, Conveyance_Division, and Conveyance_Division_Lines) that don't fit into our right-of-way parcel types. When trying to delete those Feature Classes, the outcome is a message:
I have a second Parcel Fabric, Local Government Model also, that has none of the four listed Feature Classes. So, I am not buying the "required dataset" message. Any ideas?
TimHodson
Mark,
I see messages similar to this when trying to delete a feature class if I have forgotten to first remove the parcel type from the fabric. You should be able to delete those feature classes. To remove the parcel type, right click on the fabric in the Catalog pane, and click Manage->Remove Parcel type, then in the GP tool that's presented, enter the name of the parcel type to be removed. You'd repeat this for each parcel type.
After removing the parcel type, the feature classes should be "released" from their controller, and you can try the delete again.
DrewDowling
Are the feature classes you are trying to delete still part of the fabric as parcel types?
MarkWasdahl1
Yes. I followed Tim Hodson's directions and was subsequently able to delete the Feature Classes.
TimHodson
Mark,
MarkWasdahl1
The Feature Classes would not delete until I first deleted all data contained within them. All good to go now.
